Beomaster 2200 blowing fuse
This post has 3 Replies | 0 Followers
andreis2009
Posts 8
andreis2009 Posted: Sun, Jul 16 2017 12:56 PM
Hi to all,
I've got a Beomaster 2200 in restoration now. The 1.6A fuse from is constantly blowing. I disconnected the power supply module from the main board, fuse is still blowing, so I assumed the problem is with the power supply.
When I disconnect the power supply module from the secondaries of the transformer, it's fine, so I assumed, the transformer is fine.
The electolytics are changed for the new ones - no change. Is there anything special I should check in this power supply? Seems like transistors and diodes are OK. Does anyone know what is the SBT1 and its values? (shown on my pic.) I found nothing about it in the service manual... Thank you!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jul 20 2017 8:59 AM
It'a triac. That configuration is called a "crowbar circuit". When trouble is detected, the triac shortcircuits the power supply lines causing the fuse to blow, preventing further damage. The trigger signal comes from somewhere else that is not shown on your diagram snippet.
If nothing else is connected and the fuse still blows, I guess the first possible cause is that the triac itself has failed and has a short circuit. Desolder and measure.
--mika
andreis2009
Posts 8
It was indeed a short circuit in this triac! Changing it solved the problem of the blowing fuse.
At least now I can see that the left channel is dead :-) But it will be easy to fix, since I have a good signal coming to the left output stage board, the problem is somewhere there, probably transistors.
A big thank you for your hint, Mika! Cheers!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jul 20 2017 9:11 PM
Well done! Hopefully the rest is easy Smile
--mika
Page 1 of 1 (4 items) | RSS
