See above the Playback Stream Capture button.
When starting a stream service (Apple, Deezer, Spotify, Qobuz, Tidal) on the PC, the stream can be send and distributed to B&o DLNA renderers (and Multiroom).
Note: no tags - have to start Foobar (once); start the stream service (once; than use of app of f.e. Spotify); start B&o system
Presumably it also works on a BS5 (but I cannot verify it).
Software: 1. VB-Audio Cable and 2. Foobar 2000 + plugins
Edit: principe works! But just had a system hiccup -
Edit 2: seems to be solved, reduced the resolution from 96kHz to 48kHz
