Dear friends of Beoworld!
Suddenly my beotime lost its display background light; can't remember any damage - other functions (flip display, ir commands, alarm sound) still working...
Any idea?
Best regrads
Elmar
Update: Just tried to do a kind of reset by removing batteries - and IT WORKED; -> Thanks;
best regards, Elmar
Mine will occasionally do that, when it does it's usually been a while since I changed the batteries so I go ahead and change them and it solves the issue. Never knew that just putting the old ones back in would reset anything, good to know, thanks!
Jeff
