Hi everyone,
I have a quick question, soon I will be inheriting a barely used complete Beosystem 3300 from a family member which has a set of RL60.2's. However as wonderful as the Rl's are, I would love to find and connect a set of Pentas to the system, and use the RL's somewhere else. I know the beomaster 3300 does not have powerlink sockets, however I have yet to find a complete answer as to how I should go about connecting them to the regular 2 pin DIN sockets. Would just using a regular 2 pin DIN cable and connecting it to the speakerlink sockets work, I know I wont get the display but that's no issue. Just some clarification would be great!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
You can use the Beolab Pentas via speaker wires from the outputs on the back of the Beomaster, but this may not give you the best sound quality or output power. The simpler option for best results (as long as you don't have any other speakers connected to the Beomaster) is to link the two speakers to the headphone socket of the Beomaster with this cable:-
https://soundsheavenly.com/line-in-connection/77-241-minijack-to-beolab-line-in-using-phono-rca-sockets-one-cable-for-two-speakers.html#/2-length-1m
This gives you a volume-controlled line level output (similar to linking to the Powerlink sockets on a newer B&O system) for the best sound quality - this also lets the speakers give their full output levels if required. Please set both speakers to "Auto" mode using the small switch on the hinged front panel.
This option works for all powered (Beolab) Penta models, but the speaker displays won't function.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
