Beocenter 9500 refurbishment
This post has 3 Replies | 3 Followers
Dave
France
Posts 9
Dave Posted: Thu, Aug 17 2017 1:11 PM
I'm currently giving my newly aquired BC9500 some much needed tender loving care. The seller informed me that it's been in storage for a number of years; excellent exterior condition and basic functions, but the CD mechanism needs and will eventuially receive attention. This is my first encounter with any B&O equipment, and I've already picked up a great deal of information from the forum here.
First task will be re-attachement of the glass displays to their holders. After soaking the plastic holders in  general cleaning alcohol for 15mins, the old adhesive strips were removed with ease. However, recognizing that the glass displays have a special coating, I'd like some advise on what solvent to use - if any - for the removal of the adhesive strips without damage.
Secondly, could someone please advise from where I can obtain drive belts for the tapedeck (old version) & CD drive. And also a kit of caps. The model is type 2506 with 1.2 s/w.
Thanks in advance for your attention.
Henk Bosschaart
Tricht, Nederland
Posts 6
Hi Dave,
I've just finished repairs on a beocenter 8000; I believe the cassette mechanism of the 9500 is equal.
look at http://www.ebay.nl/itm/Riemen-fur-B-O-Bang-Olufsen-Beocenter-2500-Cassette-Tape-Deck-Rubber-Belt-Kit-/272828282846?hash=item3f85d537de:g:6kwAAOSwlMFZEgXM for the 3 belts you might need. Also check for the belts for the sliding panels; they can be worn out as well.
Member Dilan can help with a capacitor set, I think.
Henk Bosschaart
Tricht, Nederland
Posts 6
Hi Dave,
Look at http://www.ebay.nl/itm/Riemen-fur-B-O-Bang-Olufsen-Beocenter-2500-Cassette-Tape-Deck-Rubber-Belt-Kit-/272828282846?hash=item3f85d537de:g:6kwAAOSwlMFZEgXM for the belt replacement.
There are also sellers in portugal and the UK - just search on e-bay.
I finished repairs on a beocenter 8000 - it is likely the tape mechanisms are similar.
For removing the strips on the glass panels I used a nail polish remover (aceton) with succes, allthough I also removed small pieces of the coating. So don't soak the complete panel, but carefully brush the sticky parts only. With black nail polish I repaired the removed coating.
Also check the drivebelts for the sliding doors - they may also be worn.
I think member Dylan can help you with a capasitor kit.
Basstard
Posts 60
Basstard replied on Mon, Sep 11 2017 6:24 PM
Contact Martin at the forum (Dillen), he can provide you with what you need.
Page 1 of 1 (4 items) | RSS
