I've noticed that I don't have any genres in N.RADIO that start with the letters A or B. And there seem to be many fewer genres than I used to see when I was running BeoPlayer before I got the BS5, although I haven't counted them to find out.
The BS5 has been hooked up for 3 or 4 months. I thought it might take it a day or two to update the genres, so I was patient, but at this point, I don't think waiting any longer is going to make a difference.
Any suggestions?
Hi I've got this same problem too this morning. Did you get it fixed? Thx
This is the answer I got from B&O:
