Beocenter 9300 upper glass panel replacement?
deugar
Posts 2
deugar Posted: Tue, Aug 8 2017 3:19 PM
Hi Everyone. Just joined this forum as I stumbled upon it and you have a heap of great information on here!
I have a Beocenter 9300 which I am in the process of restoring. Mainly dust and grime issues from neglect I'd guess. However the upper smoked glass panel is broken. Is there anywhere I can buy one of these? I am based in the UK.
Hope I've posted this in the correct place!
Saint Beogrowler
Saint Paul
Posts 780
Sometime these guys have reproductions for sale.
http://www.quality-dream-audio.co.uk/spare-parts.html
But it doesn't look like they have any now
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Aug 8 2017 4:54 PM
deugar:
It might be easier to find a defect replacement unit. I actually believe that 8500/9500/9300 uses the same upper panel, but you need to be 100% sure :)
/Jacob
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Aug 8 2017 8:27 PM
Weebyx:
/Jacob
Or from a 9000.  I successfully moved one from a 9000 to a 9500 and couldn't see any differences - BC9000s may be easier to find for parts as they often have the cracked CD spindle.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The difference is in the Dolby area. The 9000 has Dolby B and C and the 9300 has Dolby on/off only.
Other than that their are no other differences and the older versions will work just fine.
Regards Graham
Page 1 of 1 (5 items) | RSS
