Beovision 11 / Avant
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Aug 16 2017 7:54 PM
Hello All
I have a V1 in my Bedroom that I will upgrade soon to a BV11-46
My question is, is deezer accessible like it it on the moment via the Beolink or new X App.
Reason I ask is that when I control Deezer on the essence or Moment via the app I like it.
I cannot control Deezer on the V1
Does the current TV range allow remote control of Deezer via the App or it is still a TV app ???
I am thinking is seems a shame to have to use Deezer over Netlink when the TV will already have it installed.
Same question also for the avant how is Deezer controlled?
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
benjnz
Posts 114
benjnz replied on Wed, Aug 16 2017 9:25 PM
Short answer yes I use the X app to playback deezer through my BV11-46 as it's wireless NL to my Beosound Moment. Same goes in the kitchen for BS2, I generally use the X app.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Wed, Aug 16 2017 9:31 PM
The V1, BV 11 and Avant (not Next Generation) all use the same OS, so same Deezer ability as you have now.
In your V1 you can access Deezer in source menu and will activate the buggy old Deezer app. This source can be shared over NL. Through the Webmedia source you can activate the newer Deezer app, but not possible to distribute that source over NL (not to my experience anyway).
In my Horizon there is a better Deezer app but the Android OS is not yet fully functional in NL/Multiroom setup, so I do not know if it can be shared. But with a Moment you have no need for sharing Deezer from your TV, as you can join all NL tv's in multiroom play.
Hope this helps you a bit
Page 1 of 1 (3 items) | RSS
