Hi guys !
I have a BeoSound 9000 MK1 type:2526
I have an issue with laser unit.
As i press play, cd is clamped and thats all. After +-5s i get "pause"
TM: Focusing, motor and positioning works but no light from laser :(
Since B&O dont have a replacement for me, then i have a question:
What laser type should i buy ? I find cheap ones on ebay and ali.
Its a VAM12.4 ?
Thank you !
Pepi: Hi guys ! I have a BeoSound 9000 MK1 type:2526 I have an issue with laser unit. As i press play, cd is clamped and thats all. After +-5s i get "pause" TM: Focusing, motor and positioning works but no light from laser :( Since B&O dont have a replacement for me, then i have a question: What laser type should i buy ? I find cheap ones on ebay and ali. Its a VAM12.4 ? Thank you !
Most likely a cdm12.4 laser yes, but to be sure you need to look at the existing laser.
/Jacob
