how to restore beolab 8000 base ?
This post has 5 Replies | 0 Followers
olvisab
Posts 1,391
olvisab Posted: Thu, Aug 17 2017 10:21 PM
hello,
I need to restore discolored beolab 8000 bases
Do you have any tip for restoring them ? thanks
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Aug 18 2017 12:39 AM
Discolored in what way? A few years ago mine looked very grungy and gray, turns out they had loads of dust that had accumulated on them and didn't wipe off easily. I took a very damp cloth rag and wiped them down several times, rinsing it out in between, and they cleaned up quickly and nicely. Or do you have a different type of discoloration?
Jeff
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Fri, Aug 18 2017 1:12 AM
I used a soft brush and lots of water and soap on mine, then I let them dry under sun light.
The original paint is very scratch resistant.
Now they look like new 😁
Zwets
Posts 111
Zwets replied on Fri, Aug 18 2017 11:37 AM
I use a product which is like a shoe polish but especially for iron stoves. Works great and makes them nice and black again.
olvisab
Posts 1,391
olvisab replied on Fri, Aug 18 2017 2:50 PM
Thanks for your advices.
Due to the damages of the paint and its discoloration, I will directly use the satin black bumper paint that some advised in an older thread found on beoworld.
I will post pictures before/after if I can do it with my ipad.
olvisab
Posts 1,391
olvisab replied on Fri, Aug 18 2017 2:51 PM
Could you please give me a link on ebay or amazon if it is possible ? Thanks
Page 1 of 1 (6 items) | RSS
