Everytime I reply to someone ´s post, the quote doesn't appear. I use an ipad.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab: Everytime I reply to someone ´s post, the quote doesn't appear. I use an ipad.
Do you just press the "Quote" button?
If you don't use an iPad does it work correctly for you?
Regards Keith....
Keith Saunders: olvisab: Everytime I reply to someone ´s post, the quote doesn't appear. I use an ipad. Do you just press the "Quote" button? If you don't use an iPad does it work correctly for you?
I have just gone and used my wife's iPad and this response is done on her iPad
Sorry I didn't remenber I need to press the quote button when I select reply to a post. Is it new ?
olvisab:Sorry I didn't remenber I need to press the quote button when I select reply to a post. Is it new ?
It's been there since April 2012.
