Now my CD50 is the CD player in my Beolab 5000 system. But the lack of direct access to a track is a pain! I know it's as rare as hens' teeth though!
Thanks!
Jacques
Does your CD-50 have the remote control receiver built in,as it was'nt standard.
Nick
Hi Nick,
It doesn't! I need the whole package.
I used to have the receiver kit,saved for a future project,but the handsets are like gold dust!! Crop up on e.bay sometimes though.
I'll have a search in the vaults.
Thanks Nick. Will the receiver work with a Beolink 1000?
No - uses different codes. You could of course get a Beomaster 5500, attach the CD50 to it and then use the line out to the Beolab 5000 - probably cheaper and easier to find than the CD remote and board and also will work with a Beolink 1000. A few more connections though!
Peter
Peter: No - uses different codes. You could of course get a Beomaster 5500, attach the CD50 to it and then use the line out to the Beolab 5000 - probably cheaper and easier to find than the CD remote and board and also will work with a Beolink 1000. A few more connections though!
Right then.
Peter! I already have a complete 5500 stack, complete with MCP and Beolink 1000!
But another Beomaster 5500 just for that?
I didn't say it was a very good idea, but it will be a lot easier than finding the bits you need!
Well, if you send me one over for free I might be able to conceal it somewhere...
This is what you need!
Brengen & Ophalen
Peter's suggestion got me thinking,and I wondered if you could use a MCL AV kit. AKA MCL active extra speaker kit.This has three inputs,cd,tape and aux,and a variable line level output that you could connect to a spare input of the Beolab 5000.
This would not only give you expanded inputs for say i.pod etc,but would also provide remote control of the cd 50 and volume,using a Beolink 1000/Beo4.
Just a thought,but I'll keep looking for the cd remote adaptor kit anyway.
Err, yes Leslie! Is it for sale?
solderon29: Peter's suggestion got me thinking,and I wondered if you could use a MCL AV kit. AKA MCL active extra speaker kit.This has three inputs,cd,tape and aux,and a variable line level output that you could connect to a spare input of the Beolab 5000. This would not only give you expanded inputs for say i.pod etc,but would also provide remote control of the cd 50 and volume,using a Beolink 1000/Beo4. Just a thought,but I'll keep looking for the cd remote adaptor kit anyway. Nick
You could possibly use the tape connection as an output if using the MCL2AV as I believe that gives a line output. I might have an experiment with the one I have!
A kind member here is giving me an ir module to experiment on. I'll still have to figure out the codes/find a suitable handset.
solderon29: Just a thought,but I'll keep looking for the cd remote adaptor kit anyway. Nick
Found it?
Cheers!
Still looking,but also tinkering with alternative solutions too! I have a cd50,and it would be useful to operate it with BL1000 etc if possible.
Indeed! If anyone could come up with that...
Hi!
Still looking for the handset...
chartz: Hi! Still looking for the handset...
Found one in Denmark!
It is located in Struer. Thanks M.
