Hi All
I have been a subscriber to Sky for a number of years using my Beo4 remote to control the channels - works well. I am considering moving to Virgin, is there any pit-falls / drawbacks in doing so? Can you still control the Virgin STB using the Beo4.
Thanks in advance for the advice.
Paul
I had no problems at all, just check in your STB connections menu that you have Virgin as an option.
Dan
