Beosound 5 encore green screen !!
This post has 12 Replies | 2 Followers
JamesC
Posts 14
JamesC Posted: Sat, Sep 16 2017 3:17 AM
Bought a BS5 Encore from eBay, when switched on screen is completely green and the pointer also looks strange anyone has similar experience or know what might be the problem ?
Thank you guys :-)
Rob - Danish AV
Melbourne
Posts 376
It looks like is is in a 'safe mode' ?
The standard Beosound 5 operates on windows, I would guess the Encore is a simpler version.
tried restarting or completely powering off from the mains?
JamesC
Posts 14
JamesC replied on Sat, Sep 16 2017 8:13 AM
Thank you Rob, I'll give it a try again
CB
> You are Here <
Posts 1,762
CB replied on Sat, Sep 16 2017 8:17 AM
Hi
Not sure about the OS of the BS5 (Beomaster 5 runs Windows), but the BS5 Encore has Linux.
BeoMotion
Posts 384
BeoMotion replied on Sat, Sep 16 2017 12:32 PM
Never saw something similar...
If you display an album cover in full-screen mode, are all colors of the picture correct?
If you power-cycle it, does the green background also appear right after switching on? (when the "Bang & Olufsen" text is shown during boot-up)
Have you tried a factory-reset via the menu?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 16 2017 1:11 PM
if you're in luck you have only a loose cable to the LCD
JamesC
Posts 14
JamesC replied on Sat, Sep 16 2017 1:24 PM
Yes, I had reboot,  reset to factory setting..... and it's green screen all the way.......And I haven't managed to play the music from my iPhone connected with USB at front .....  it seems complicated or there are more faulty :-(
JamesC
Posts 14
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 16 2017 1:46 PM
JamesC:
I don't believe that will work! Place some files on an USB and put it in the USB slot. Than try again.
TWG
Posts 1,672
TWG replied on Sat, Sep 16 2017 2:02 PM
I only know such a screen issue from defective graphic card chips or when the graphic card has driver issues. Maybe it's just a software fault, maybe there's something wrong with the internal graphic chip / GPU or just a loose cable from the display. That's only speculation as I don't know on which system the Encore is based. Some say Linux, some say Android... and as always, there's sadly no info from B&O.
The iPhone / iPod can NOT be used as Apple does NOT support the simple mass storage mode for music!
You can use every device that supports a simple USB mass storage mode for its files, like USB Sticks, USB HDDs and e.g. Sony Walkman, Pioneer, Onkyo etc. high resolution audio players etc.
For your iPhone you could use an Airplay or Bluetooth adapter via Line-In or a DLNA software for iPhone. Than the iPhone acts as a DLNA music server and you can use the Encore to see and play your music.
See here: http://www.plutinosoft.com/airmusic
BeoMotion
Posts 384
BeoMotion replied on Sun, Sep 17 2017 11:10 AM
TWG:
The Encore is based on a Freescale MPC512x (ppc architecture with embedded graphic unit) as far as I remember. It's running an old wind-river Linux distribution for embedded systems. Bootloader is u-boot with tftp support, it has two rootFS's with bank switching on NAND and an replaceable microSD card where all user data (databases, etc.) gets stored. SSH server is permanently running on port 909 but started in "not-forking" mode (which makes it invisible to standard port scanners).
I'm not sure whether a loose cable can only affect the background color. In the picture it looks like black and white are working normal on the "arrow" graphic. If it's a hardware fault I would say it's the LCD display (or the embedded display controller) itself.
If the author has the latest software installed he can go into "service menu" and enter "service mode". This should show a grey background labeled with a large "service mode" text and the IP address. If it's still green, I have my doubts that its a software issue.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Sep 17 2017 11:45 AM
Could it be a green wallpaper ?
Or a corrupted original wallpaper file ?
BeoMotion
Posts 384
BeoMotion replied on Sun, Sep 17 2017 3:18 PM
CB:
No window manager, no wallpaper. It's embedded Linux...
Although in theory file corruption could be possible I think this is -very- unlikely the reason.
Page 1 of 1 (13 items) | RSS
