I currently have a BeoCenter 6-23 in my masterlink setup which I have STB connected to to watch digital TV. I would like to add a small TV in the laundry room and connect radio and video over masterlink.
What TV should I buy - another BeoCenter or would a BeoVision 6-22 work also?
Thanks for advice!
/Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Anyone?
Any of the TVs will work - I have a BV3 that works in the bedroom using the STB of the Avant DVD in the main room - can get all sources from Avant and BC2 in main room and also N.Music from computer in study.
Peter
Rivenflush: Hi, I currently have a BeoCenter 6-23 in my masterlink setup which I have STB connected to to watch digital TV. I would like to add a small TV in the laundry room and connect radio and video over masterlink. What TV should I buy - another BeoCenter or would a BeoVision 6-22 work also? Thanks for advice! /Riven
Yes, BV6-22 will work great as a link TV - I had one in the bedroom for years, now it has been moved to another link room.
The problem in your setup might be the BC6-23 in the mainroom - it will work as a videomaster (you want to distribute video via the RF linksystem?).
As far as I know, the small BV6/BC6 has no RF modulator built in, so there is no RF out socket.
But there is always a solution ">
Should be possible to connect an RF modulator the the AV1 SCART socket. I must have one somewhere in my house...(?)
Stefan
Yes, this was exactly what I had in mind - using my esisting BC 6-23 as video master
