Hello Beofamily!
A friend and I have been troubleshooting an issue with a pair of Penta 2s connected to a BS3000. One Penta works as it should and goes into standby when the Beosound is turned off, the other stays on. Anyone have some insight on a fix for this?
Thanks!!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Just an update, this problem is the same if it is connected to a BS3000 via powerlink as well as when connected to a non B&O source with the phono inputs... Not sure if that helps with the troubleshooting...
