Can a Subwoofer be Ceiling Mounted? (Beolab 16) Yes it can. Photo now attached
This post has 18 Replies | 2 Followers
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo Posted: Wed, Mar 22 2017 6:45 PM
Linked to this thread where I asked another question too.
I have a Beolab 15 & 16 speakers and subwoofer and am having it set up in my dining room.
Can the sub be ceiling mounted with the speakers or should it be below ear level? I'm thinking of ceiling mount due to it being easier than drilling into solid brick walls to mount it.
Stoobie
Mogelmose
Posts 88
Mogelmose replied on Wed, Mar 22 2017 7:24 PM
If you read into the notes about the Beovox Cona sub B&O themselves has concluded that the human ear cannot sense in what direction bass notes come from. Thats why the made a "stereo" sub in a mono enclosure.
With that in mind i googled "subwoofer in ceiling" and got several threads from especially home-theater forums that tells me the same thing.
Go ahead Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
The only problem I see there is, that a decent subwoofer mostly is quite heavy - the BL16 = 5.1 kg.
Not everyone wants to have that in the ceiling above ;-)
Since you are asking about ear level/directivety, you should be a lot more carefull with the placement of the 15's than with the 16.
The 15's can be tilted. Be sure, that they point towards your listening position - at least that they don't point away ;-)
Stoobietoo
Exeter, Devon, UK
Posts 692
Hi Mogelmose and Millemissen,
Thank you for your answers, in the back of my mind I thought I remembered hearing it would be OK but I would rather check (especially with beoWorlders!). It is going in a purpose built section of the ceiling which I will be building myself. I will be able to ensure that the mounting points for the speakers are very sturdy and I will be using MDF as the ceiling in that section and not the usual plaster board.
The sub will sit between the two speakers (mainly for aesthetics) and the two speakers will be set to tilt to the optimum position.
Once it is done I will post pictures. It will be completed in about 6 weeks but I will start on the frame on this weekend.
Thanks again for your help
Stoobie
BeoMegaMan
Posts 601
You're fine. I have been apart of jobs where it has happened. I would advise to keep it as far away from any can lights as they will vibrate under a load from the BL16.
Ah, you know... A little B&O here, a little there
GregKo
NYC
Posts 25
GregKo replied on Wed, Mar 22 2017 11:28 PM
Stoobie -
I understand the desire to center the sub between the speakers for aesthetic reasons, but just be aware that you will typically get the best bass response and integration with your main speakers with the sub place in or near a corner of your room.  Before you commit to all the logistics involved in mounting the sub you might consider trying it in different placements on the floor first and see what sounds best to you - If you can, try it on the floor between the speakers below where you ultimately will want it placed and see how it sounds.
By the way - Kudos to you for trying something different!
Greg
Beocenter 9500, Beomaster 6500, Beolab Penta MKII, Beolab 5000, Beolab 3000, Beolab 4000 MKI, Beolab 4000 MKII, Beogram 3300, Beogram 3000, 2X Beolink 7000 RDS, 2X MCP 6500
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Stoobie,
Yes, as long as the ceiling is solid (and the users of any rooms above don't object!) then a ceiling void could be suitable for certain subwoofer designs, including Beolab 16.
In fact, Kef make a also compact sub/sat speaker system called the SoundLight, which is specifically designed for ceiling mounting (this has satellite speakers which are the size of GU50 down-light fittings and a subwoofer that sits in the ceiling void and ports through two more GU50-sized fittings.
Beolab 16 has two opposing drivers that cancel out the majority of mechanical vibration, making it a good candidate for in-ceiling use in the right environment.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Posts 14,680
GregKo:
Will be difficult to 'try' a BL16 on the floor - the 16 and the BL15's were created for wall-mounting.
Stoobietoo
Exeter, Devon, UK
Posts 692
Thank you all for your answers, it makes me feel very confident things will be fine with my setup.
Very much appreciated.
Stoobie
frog
Camberley UK
Posts 624
frog replied on Wed, Mar 29 2017 11:50 PM
I recall that with the Beolab 2, the manual states that it should be between the two front speakers. Never new why (and I didn't do that either)
Stoobietoo
Exeter, Devon, UK
Posts 692
The room is taking longer than planned, (the problem with being a perfectionist) but it will definitely be worth it. Sorting out the connections for LED uplighting and the specialist coving has upped the time and budget.
Once it is done I'll share pictures and listening experience.
Stoobie
Stoobietoo
Exeter, Devon, UK
Posts 692
Here is a picture of the project so far.
Stoobie
Aussie Michael
Melbourne, AU
Posts 3,730
That's something really special and unique Doobie.
beojeff
USA
Posts 2,012
beojeff replied on Fri, Apr 28 2017 1:48 AM
References to the BeoVox Cona aren't quite relevant considering current subwoofers. The BeoVox Cona was intended to compensate for the shortcomings of bass of the BeoVox cx50 and cx100 speakers. The Cona does not provide a proper LFE channel as we expect from subwoofers today. I know. I had a BeoVox Cona. It was really pretty worthless.
The claim that the human ear cannot discern the placement of a subwoofer is not quite true. When I added a second BeoLab 2 and with careful, proper placement of the second BeoLab 2, there was a HUGE difference in the LFE! With proper placement of a second subwoofer, the sound becomes tremendously more natural. The human ear finds that the second subwoofer (with proper placement) makes the LFE placement less noticeable and more natural.
Stoobietoo
Exeter, Devon, UK
Posts 692
Bit of a disaster with everything. We tested before installing and all worked. We then completed the section around the speakers and amplifier only to connect and for it not to work. We had to rip the whole lot out to find out what was wrong only to find we has connected the Beolink Active into the service socket and not the Powerlink Socket. Easy to do in the tight confines of the setup. It has made a mess of everything but at least it was not an expensive trip to B&O for a repair.
More photos to follow when there is more to show. I have to say, I think the Beolab 15/16 is probably over kill in that small room. I'm thinking I should have just used my trusty BeoVox 100s. They do sound stunning but probably would have been better in the living room, but they were an impulse buy for there so there they stay!
Stoobie
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 8:26 AM
Clean setup 👍🏻
You're giving me some ideas for my main house 💯👍🏻🔥
Regards
Kiran
Born in NL; I ride ML
Stoobietoo
Exeter, Devon, UK
Posts 692
After having to take the installation apart, it took a while to get round to putting it all back together.  But here is the finished project. We put colour changing LEDs above the coving ( leaving a gap all the way around).  We have a few things to sort before we can move the dining furniture in. The sound is amazing ( probably too good for such a small room)
Stoobie
Aussie Michael
Melbourne, AU
Posts 3,730
Wow.  Keep us posted please
Kiran
UK
Posts 1,023
Kiran replied on Tue, Dec 19 2017 4:08 PM
Stoobietoo:
Stoobie
That looks so good!
Regards
Kiran
Page 1 of 1 (19 items) | RSS
