I need to replace the badly perished foams on my Beovox CX100 speakers, no problem in that. The question is though, should I also replace the gaskets as a matter of course?
Nick
SurreyNick:I need to replace the badly perished foams on my Beovox CX100 speakers, no problem in that. The question is though, should I also replace the gaskets as a matter of course? Thanks Nick
Thanks. I will order foams and gaskets :)
Whilst you may want to opt for replacing the gaskets, we have found in our testing when upgrading the CX-series with a BeoCreate 4-Channel Amplifier that the original gaskets are almost always good enough to do the job. As long as it is not broken, it will squeeze between the back panel and the aluminium profile nicely, providing a seal.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Oh, well, that's very encouraging. Perhaps I won't need to incur the cost of gaskets too.
I shall inspect them carefully and go from there.
Thanks.
