beolink 7000 not working.
This post has 1 Reply | 0 Followers
thetandyman
Posts 17
thetandyman Posted: Sun, Oct 15 2017 1:18 AM
I may have mentioned this before,  but I have a beolink 7000 that has new batteries installed..  It lights and sits up on a table,  but doesn't respond.  Is there another battery inside that needs to be changed?   It won't respond to any touches on the blue screen.  It used to work before I had the battery pack changed.  Any ideas?  Thanks so much.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sun, Oct 15 2017 7:15 AM
thetandyman:
Didn't you read the responses you got on your former post ?
Please respond to that thread instead of just starting new ones, that makes it difficult to help you.
/Jacob
Page 1 of 1 (2 items) | RSS
