Hi :)
I have beocenter 9300 with two s70 speakers. In basement i have MCL2A connected to beocenter with cable. Into MCL2A "box" there is one control panel and two cx100 speakers. There is no more space to plug another cx100 (i want them in other room)
what can i do ?
i have two MCL2A with two control panels.
can i connect MCL2A to other MCL2A (plug cables inside box (so one hole two green's cabels, two red's, two yellow's etc. ;) )
So to another MCL2A box i will plug another cx100 .
Can i do this ? what kind of cable i should buy to do this ? i think the same cable like that one to plug into bocenter 9300 can i still buy it ?
Yes, you connect the MCL2As in serial, so green to green etc. There terminals can be quite tight.
Yes you can safely connect up to four MCL2As in parallel - connected just as you stated by connecting two wires to each terminal inside the MCL2A.
Ideally you need a find some more MCL cable - it occasionally pops up on eBay. Otherwise someone else on the forum may be able to suggest an alternative cable.
Look here: http://www.ebay.co.uk/itm/Bang-Olufsen-B-O-Grey-MCL-Cable-3-3-mtrs-long-/311959314281?hash=item48a2395f69:g:N2wAAOSwENpZkExR
