Anyone know I it is possible to use a BEO4 with the Beosystem 4 - it seems that it will only work with the Beoremote One or the BEO4 with the joystick to me. I've a lot o BEO4s and its a shame if I can't use them.
It is possible. There is a setting to switch to Beo4/5/6. Then, you must assign the sources, for example to DVD, V.MEM, TV, etc.
I’ve tried that. The Go button doesn’t work on the beo4.
Beosystem 4 , Beoremote One, Samsung LED 65 Zoll, ATV4 PUC, BL 8000 Frontspeaker, Center BL 7.1, BeoPlay S8 black Rear Wandhalterung, Beosound Essence MK2 mit IR an Beolink passiv an Bose 161 weiß, Beomaster 3000 mit Beocord 3000 an BeoVox CX50 weiß, BeoCom 1401 mit IR Control, BeoCom 2000 weiß, Beoplay M5, Ex-Beosound Ouverture RDS, Ex-BV 10-40 MK3 mit Beo4 DTV an Dreambox 500V2, Ex - Beoplay V1-40 weiß , Ex-BV 8-26 mit Beo4 DTV an Technisat Digit S2e PUC, ex BeoSound 3, Ex-Beolit 12 Darkgrey, ex B&O A8 Earphones
Isn't there a setting in one of the set up menus to select Beo4 with or without navigation?
Regards
Opman
Opman: Isn't there a setting in one of the set up menus to select Beo4 with or without navigation? Regards Opman
With Bsys3 yes,there is option to select Beo4 with/or without navi button.Don't know abt Bsys4
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
No, with the latest sw-versions of the BSys3 (and BV10,8 etc), you can choose between the two versions of the Beo4.
The Beo4/navi can be set to either Navi or old Beo4 function.
I ws hoping I could pick up the Netflix and Prime buttons on the Beoremote one using the connected MLGW, but it seems it doesn't log the keys at all. I suspect the software version of the MLGW is an issue as it was only last updated in 2017.
Would a BLGW be able to read them I wonder.
frog: I ws hoping I could pick up the Netflix and Prime buttons on the Beoremote one using the connected MLGW, but it seems it doesn't log the keys at all. I suspect the software version of the MLGW is an issue as it was only last updated in 2017. Would a BLGW be able to read them I wonder.
I had thought the same thing as you did. The BLGW did not detect the the Netflix or Prime buttons. I had hoped the buttons might send out a CONTROL command, but it seems that they do not. I guess the buttons only work with bluetooth.
Interesting. I'll see if they do send out a bluetooth command. If so, I can capture them that way.
Well while there was a response - the remote is quite modal - so I can't easily use it as a beovision (IR) remote with those buttons active. Waste of time really!
