Hi, I have a Beosound 9000 which have the laser ready broke, and I need a part (image below) to fix it. Does any one might suggest where to find it?
Many thanks for your help.
Mauricio Rico
Sorry image was not attached. The CD laser reader item number is:
8420001
14-04-14
CD mechanism BeoSound 9000
Regards.
Could you tell on which page of service manual your part numer is shown ? For me it seems that your Beosound 9000 is an older version.
The best way is to picture the laser mechanism, it should have a label with type and number
Many thanks Peter for your prompt answer, Ye it is an older version, I bought it more than 12 years ago. I`ll ask to the B&O technician for the part number to share with you, to see if you can help me to find it out.
Best regards.
