bridging a beosound passive
Steven
Brown
Posts 1
Steven Posted: Wed, Oct 11 2017 10:02 PM
Hello everyone!
First time posting.
I have a BS 9000 powerlinked to a passive driving two non-BO speakers. i just purchased 2 beosound 4000's i am going to connect to the 9000. I would like to remove the non-BO speakers and bridge the passive into 1 beosound Penta that i converted to a Beovox because the amp died. Can i bridge the passive? Or, can i connect both channels of the passive to the 1 beovox? Or should I just use one channel to the Penta?
Any comments or advice welcome.
Thanks!
Steven Brown
BS9000 MK II-BL4000's-Beovox Penta-Beo 4
BS3000-BL Pentas MKII (THE greatest speaker ever made!) Beo4
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker replied on Thu, Oct 26 2017 11:40 PM
I have similar interests in knowing if it is possible to bridge a single passive speaker with a MCL converter.  Has anyone here done that?  I just don't want to hurt any of my beloved B&O equipment.
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Oct 27 2017 11:16 AM
bridging a MCL 2P, MCL-MC or Beolink converter is not possible because for bridging you need one non-inverted signal on the first input  _and_ the same signal inverted to the second input! Another point is that the amplifiers 'sees' only the half impedance of the speaker. This might be problematic then.
The amplifiers are also not designed to drive a speaker in parallel!
The only thing you can do is drive two seperate speakers with those devices without modifying them internally!!
Ralph-Marcus
Tucker
Posts 439
Tucker replied on Fri, Oct 27 2017 2:27 PM
Thank you for the clarification!  Much appreciated!!!
-Tucker
Page 1 of 1 (4 items) | RSS
