Beolink Passive Amplifier Type 1656 without IR-eye
This post has 3 Replies | 0 Followers
MokiPhone
Posts 6
MokiPhone Posted: Thu, Nov 2 2017 9:24 PM
Is it possible to use the 1656 without the IR-eye? I have connected it to a Beolink Converter 1611, but it doesn't seem to turn on.
Millemissen
Flensborg, Denmark
Posts 14,680
You must use a fully wired PL cable - otherweise the amp won’t turn on/off.
Millemissen
Flensborg, Denmark
Posts 14,680
Click to see full pic.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi MokiPhone,
Yes, Millemissen is correct, you need a fully wired Powerlink mk.2 cable like this otherwise the Passive won't switch on:-
https://www.soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
Kind regards, Steve.
Steve.
Page 1 of 1 (4 items) | RSS
