Is it possible to get a beocenter 6 unlocked? I have seen a tv on eBay and interested in purchasing. However it does not have password.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
hmmm if password was set, it could be reset, saying that I'm more stacked in past and most equipment require hard push rather than password, just to make sure what password are you talking about for wi-fi or the menu is locked? best be to into manual - I haven't got that 1 (I'm up to beocenter 2) - I'm sure any B&O specialized dealership (with workshop) be able to re-set / unlock or and some other guys in here know more about the new stuff
all the best
bob
Don't worry - be Happy
There - from manual:
Use your pincodeIf your television has been disconnected fromthe mains for 15–30 minutes, the televisionprompts you for the pincode when youswitch it on. You may not be able to switchthe television on immediately – waitapproximately 30 seconds and try again.IMPORTANT! If you are prompted for a pincodethe first time you switch on your television,contact your Bang & Olufsen retailer.When your television is switched on …> Enter the code digits using the number buttonsor .> Press GO when the last digit is entered.> Your television starts up again.Five incorrect entries will cause the television toshut down for three hours, during whichoperation is not possible.If you have forgotten your pincode …> Contact a Bang & Olufsen retailer to receive afive-digit mastercode.> When the television prompts you for yourpincode, press and hold to bring up theMASTERCODE menu.> Entering the code digits using the numberbuttons or and pressing GO will deactivateyour pincode and reactivate your television.To use the pincode system again …> Follow the procedure for activating the pincodesystem.
This is a beovision 6, sorry for misconfusion. No password on tv due to previous tennants just leaving it! So Ebay link says.
Hi Chris,
Some B&O stores are happy to give you the original PIN. Problem occurs if the original owner then changed the PIN for a number that suited him. Then a master code is needed from Denmark, very unlikely you will get this for obvious reasons.
Jonnie
Maybe I am just not very trusting, but that sounds dodgy to me, and personally I wouldn't go near it.
If the seller had a legitimate reason for not having a pin, they would go to b and o themselves. The fact that they are prepared to take a hit on price and make it the buyers problem is strange, and I would think/hope you would have real problems getting a code for it without proof of purchase.
No problem there it figures it was Beovision and as other guys, especially Rednik said - it sound dodgy and as an buyer you shouldn't have to deal with that,it's seller's responsibility, despite facts such many things in live are dodgy - whom just might turn out not to be legitimate owner after all...
.......... walking away whistling ..........
