Hello,
I am comsiderimg buying a Beovision 11-46 to match 2 beolab 18. At this moment I have a Beosound moment and a loewe individual. Loewe audio out to line in of the moment for the sound.
The goal is to get rid of the moment and only have the Beovision 11 with the beolab 18.
Other then watching tv we listen 90% of the time radio and 10% deezer.
radio is available from my dvb-c probider. I assume I can select this as a source with the remote?
My question is how can I start my deezer content. At this moment I use 90% of the time the bang & olufsen app for deezer and radio (tunein). Is that app also available for the bv11? If that is the case then my solution is simple. I used to stream from my nas with twonky but deezer replaced that all so no need on that part.
hopefully someone knows If radio and deezer is easy integrated in the Beovision 11 so I can sell the moment and have a cleaner cabinet in my living room.
I know that the horizon had maybe more integrated feutures (tunein) but I do not like the Android os.
regards Edwin
