Hello all!
It is almost a year I am building a home cinema setup consisted from a BeoPlay V1 an EPSON 7300 and many different sources. As my V1 has no HDMI output I have a bought the AT-UHD-SW-52 in order to hook up all my sources and mirror them to the V1 and EPSON. I recently acquired a matrix activation key and I am trying to complete my set up but I run into some problems which I do not know how to tackle.
1 Although I choose the ATLONA device in the PUC list I can not control it via my remote (I have tried with a BEO 4 (DTV), a BEO 6 and a BeoRemote One).
2 It seems that the only device I can control is my popcorn hour which is connected to PUC 2A
3 PUC 2A will not control the matrix.
The goal is to be able to control all the devices connected to the matrix via a BEO 6 independently if video is played by the V1 or the EPSON.
Any help would be VERY welcome :-)
Get this app then you can program the beo6 to work all the third party stuff.
It works well.
StUrrock: Get this app then you can program the beo6 to work all the third party stuff. It works well.
Hello StUrrock
I have already programmed my beo6 to work with all the STBs I have but my setup is a hide-away. All STBs are inside a cupboard.
