does anyone have experiences with this TV in a B&O environment?
I am thinking of replacing my BeoVision 4-50 with The Frame connected to a BeoSystem4.
As The Frame has (as far as I know) only a Bluetooth and no IR-Control, I wonder, if it can be controlled with my BeoRemotes (Beo4, Beo6, BeoRemoteOne) via PUC. Does the TV start up automatically if it gets an HDMI Signal from my BeoSystem4?
Any insight are welcome.
Best regards
Doc Leisure
I've just did the same but I will connect all my sources to the Almando multiplay decoder (BeoSound 9000 / Sonos Connect / TV sound).
It seems to be very simple : you connect all your B&O speakers to the Almando black box (up to 6) and you connect all your sources.
You can control your sources with the Samsung One Remote I assume...
Fred
