Hi
I just noticed the B&O App was updated with Beovision 14 support, but the BeoRemote app still can't see the tv. The B&O App however only allows me to turn the volume up/down (which works great!)
Does anyone here know if the B&O App is supposed to replace BeoRemote App with all the remote features, or if I can hope for remote app update to include BV14 support. I asked here before but it seems more and more unlikely it will happen now that the BV14 rumored to be terminated within 6 months. I'd love to see an update though. If there is a TestFlight account I could volunteer to beta-test I'd love to apply for that.
Fingers crossed.
Hello Appear,
I’m using BeoRemote app for V1/ BeoSystem 4, and it works 95% of the time, perfectly. For the other 5% it’s usually that the app can not connect to the TV. The B&O app works, but the functionality is ultra limited compared to the remote app. I rather hope they don’t retire it.
I’m maybe guessing it’s an Android/BeoSystem compatibility headache?
