Beovox C40
This post has 6 Replies | 0 Followers
woop
Posts 22
woop Posted: Thu, Sep 13 2012 10:08 PM
Hello,
I recently purchased some Beovox c40 bookshelf speakers. I don't have the original amp e.t.c. so was wondering if anyone is running these on separates that aren't b&o? and could offer any advice -  cabling and what sort of rms the amp would need to be.
Thanks.
Søren Mexico
Mexico City
Posts 6,411
Here specs use normal speaker cable, if you speakers came with cable and plugs, the flat pin on the plug is negative.
woop
Posts 22
woop replied on Thu, Sep 13 2012 11:55 PM
Thanks, any suggestions for a suitable amp? Was looking for something of a similar age.
Bob
Charente, France
Posts 418
Bob replied on Fri, Sep 14 2012 12:36 AM
Beovox C40 Specifications Type: 6324, 6322
Continuous load 40W
Music load 50W
Impedance: 6 ohms
Frequency response +4 -8 dB 80 - 20,000 Hz
Sensitivity 8W
Gross volume 4.4 litre
Woofer: 10cm
Tweeter: 2,5cm
Dimensions W x H x D: 11 x 20 x 20 cm
Weight 3.5 kg
any B&O of 1979 - 1983 will suit nicely ....
Don't worry - be Happy
woop
Posts 22
woop replied on Fri, Sep 14 2012 10:32 AM
I've been looking at the various beomasters from this era. Only thing I'm not sure about is connectivity as I have other separates (record deck and squeezebox) I would like to run through the amp and would possibly like to add more in the future.
Søren Mexico
Mexico City
Posts 6,411
It all depend on how much you want to spend, and how good you are with electronics, nearly all vintage will need restoration or repairs, Most of these receiver/amps has phono and 1 or 2 tape inputs and 2 or 4 speaker out, But you can add a source selector, to a tape input, with as many sources you may wish. For receivers/amps take a look here
woop
Posts 22
woop replied on Fri, Sep 14 2012 5:28 PM
Thanks for the link...should be able to find something suitable.
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
