Hi.
I have an LPrecord-player I want to connect to my BeoMaster 1500. The recordplayer has a ground cable that needs to be connected to te ground connector on the BeoMaster, but where can I find this on the Beomaster 1500?
If your Beomaster doesn't have a fingerscrew for this, you can fit the grounding lead to one of the screws at the Beomasters bottom plate.
Thanks a lot. I'll try that
