I recently bought an old Beogram 6000 and a Beomaster 5500, to Play LP's. I owned a pair of argon speakers, and i have bought the 2 din adapters to connect Them to the Beomaster. I cannot Seem to get any sound from Them when i Play my records.
I hope someone might be able to help.
Hello. Thanks for the advice. It turns out, that there is Sound coming through the radio output, but still nothing from the phono output. Do you have Any suggestions for the reason for this? Thank you for your help.
I know this is a silly suggestion, but have you plugged the Beogram into the correct socket?
Peter
Peter:I know this is a silly suggestion, but have you plugged the Beogram into the correct socket? Peter
I have checked, and troede different combinations, and it is correctly plugged in. It is the Beogram 6000 from 1981, (https://www.beoworld.org/prod_details.asp?pid=300). Can it be a problem with the phono line in the Beomaster?
I finally made it Work, which is very nice. My next problem is, that there is a broken pin from the speaker in the speaker 2 female plug in the Beomaster, and i cannot make it Play anything through the speaker 1 plug. I have a beolink 1000, can i somehow switch to the speaker 1 output with that? Thanks
I don't have Any experience repairing electronics, so that is probavly not a good option, No. I have troede Lots og different things, but can't Seem to get the broken pin out. Would it be an expensive repair if i get a b&o specialist to do it, or is there maybe a clever trick to get it out?(I live in Copenhagen, so there Are a few)
And i don't know what made the Beogram suddenly Play, but i tried fiddling with it, and connect and disconnect the different wires, and suddenly IT worked. :-)
