Beosystem 4
This post has 5 Replies | 0 Followers
Beosince98
Posts 274
Beosince98 Posted: Sat, Dec 9 2017 11:42 PM
Thank you for welcoming me to Beoworld!
I have owned Bang&Olufsen products for about 20 years and have, for the most part, been very happy with them.
I currently own a 55 inch Avant and am now thinking about an upgrade. I was thinking about buying a Beosystem 4 with a 3rd party TV as I want quite a large TV and the ability to also connect a projector (I do not really care about 4k). I was wondering if it is possible to use the Beosystem 4 to control the Avant motorized Stand? If so, I would simply buy a Beosystem 4, a large monitor, a Beolab 10 and then have a makeshift Beovision Avant.
Thank you in advance for your comments!
Beosince98
Posts 274
Has anyone tried a similar setup with the beosystem 4?
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Dec 16 2017 9:48 PM
Projector out only with Atlona Matrix as far as I remember.
Sal
California, USA
Posts 1,197
Sal replied on Sat, Dec 16 2017 10:50 PM
The back panel of the BS4 has a "STAND" input socket, which was intended, I believe for the BV12 stand, however, I'm sure B&O can manipulate the SW for a purchaser for the B&O stand of their choice. Perhaps that's an option in the SW itself, to identify the stand it is connected to. Perhaps merely connecting the stand cable from the Avant stand can allow the SW to identify it and have you be able to operate it.
Depending on where you place the Beosystem4 (if you place it far from the stand itself) you may need an extension for the stand cable -- don't know if they make those.
Beosince98
Posts 274
Sal:
I contacted Bang&Olufsen about this, and it is not possible.
Sal
California, USA
Posts 1,197
Sal replied on Mon, Dec 18 2017 3:37 PM
Beosince98:
Thata too bad.
Page 1 of 1 (6 items) | RSS
