hello,
This is 2nd time in 10 days. I need to unplug one beolab 5 and wait until the led light off otherwise it didn't power on, it stayed on standby.
The beolab 5 have also a digital cable plugged in but I don't use it anymore. Only one bl5 is concerned and each speaker has its own powerlink cable.
Does it happened to you ?
They are used with a beovision 7 55 no beosoud or beocenter
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Put your Speaker in option 0
Since you connected it with BV7-55
No need for the sync cable.
The powerlink cable is enough
You need to put it on both speakers and point it directly in the IR of the speakers.
To do that, Press LIST and STANDBY button
then look for OPTION
then L.OPT
then press 0
Hope this will help you
Hi
thanks for your answer but is it explaining why it worked perfectly only with the tv and now one of them seems to misunderstood the command.
