Beovision 10-46 MK versions ?
This post has 5 Replies | 2 Followers
gerard
Luxembourg
Posts 331
gerard Posted: Sun, Sep 3 2017 1:49 AM
Does anyone know where I could find the existing MK versions for the BV 10-46 with their type numbers and differences?
Thanks'
Gerard
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Sep 3 2017 3:31 PM
Here's what I remember..  I'm starting to forget already! Surprise
________
BeoVision 10 - 46 Mk1  - Type Number 9565
2 x HDMI + DHD Freeview (HD in Europe, SD in the UK)
_________
BeoVision 10 - 46 Mk2 - Type Numbers 9566-9567
3 x HDMI + DHD Freeview (HD in Europe, SD in the UK)
__________
BeoVision 10 - 46 Mk3 - Type Numbers 9555-9556
3 x HDMI + T2C Freeview (HD in Europe and also HD in the UK)
__________
Hope this helps.
The BV10 is a great TV.  Add an Apple TV, FireStick, Chromecast etc, plus a pair of BeoLab 6000's and you've got a cracking 2.1 set-up for buttons!
gerard
Luxembourg
Posts 331
gerard replied on Mon, Sep 4 2017 1:21 AM
Thanks Lee,
what do you understand by DHD Freeview?
Is that DVB-S2?
If I understand you right, there is no big change in panel quality from MKI - III ?
I'm looking for a remplacement for my AV9000 which I own for 25 years now.
I would love to get a BV 7-55 MKII but they are to expensive for me at 4000£ and it would be a hard work to explain this choice to my wife when you can get a new 55 SmartTV for less then 1000£ at every corner.
A 7-55 with BL10 would be perfect [:\'(]
gerard
Luxembourg
Posts 331
gerard replied on Wed, Sep 6 2017 3:54 PM
Does anyone know if there are differencies concerning the CI slot in the different MK versions?
Do they have 1 or 2 CI+ slots?
gerard
Luxembourg
Posts 331
gerard replied on Tue, Nov 21 2017 8:54 AM
Hi to all,
do you know if there are pros and cons to mk1 vs mk3 versions of the BV 10-46
Thank's for your help
gerard
gerard
Luxembourg
Posts 331
gerard replied on Mon, Dec 18 2017 6:34 PM
No Ideas concerning the pro and cons to BV 10-46 MKII vs MKIII ?
Page 1 of 1 (6 items) | RSS
