Beovision 32 avant
This post has 1 Reply | 2 Followers
Ace2king
Posts 2
Ace2king Posted: Sat, Dec 30 2017 1:36 PM
I have had a beovision 32” Avant from new in 2000. I have used it with both sky box and more recently a virgin TVIO box both with Scart, however I recently got the new Virgin V6 box that has no scart and only HDMI, I bought a scart-HDMI adaptor for the TV end but can’t seem to change the input on the tv setup / connections menu. Both the AV STB (V.AUX) and the Decoder STB (SAT) menus offer a long list of STB models but no mention of Virgin the TVIO box worked with SKY DIGITAL as the input but the V6 doesn’t .
Any advice would be warmly welcomed.
many thanks
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 30 2017 1:49 PM
Does the old TVIO remote work the V6? If not, the codes have changed and you are not going to be able to control it via the Avant but will need to use the Virgin remote. B&O will not be updating the list I am afraid -still use mine with a Sky box and multiroom with a BV3!
Peter
Page 1 of 1 (2 items) | RSS
