Help with mx 4000 and remote, av1/av2
This post has 3 Replies | 2 Followers
Philipka
Posts 5
Philipka Posted: Sat, Dec 30 2017 5:12 PM
Bought myself an mx 4000 from an old man, i got a remote along with it. The remote is not tagged with anything.
The only thing i can do with the remote is turning the tv on and change channels with the numbers, nothing else. Have i gotten the wrong remote? Ive tried with this remote and two beolink 1000's. What can i do? Could a Beo4 remote fix my problem?
Philipka
Posts 5
I can ass that the problem i wanna solve is that i wanna get to the av1 or av2-"channels"
Stoobietoo
Exeter, Devon, UK
Posts 692
Hi there,
It looks like you have a Video Terminal remote control so I'm not sure it is fully compatible with the TV. The lable on the back of the TV shows it is a Beo4 version so will probably only be fully controlled by a Beo4 remote. It think the remote you have will only give basic control.
Stoobie
Stoobietoo
Exeter, Devon, UK
Posts 692
On the link below it shows the keys to press on the Beolink 1000 that should correspond to a Beo4 remote and control the Beo4 MX TV you have. It might not control everything but you may be able to use one of your Beolink 1000s to control the TV enough not to need the Beo4 remote.
Link
Stoobie
Page 1 of 1 (4 items) | RSS
