This should have been a relatively simple repair, adjust the speeds on the turntable, however due to its location, I had to unplug it and move it to a place that I could work on it.
So i unplugged the unit, moved it to somewhere suitable, removed the turntable and plugged it in. Only the unit is now dead except that the two balance LED's are lit.
No standby, no ! wait message nothing.
Can someone help me please.
As an aside, whats the difference between the Beocentres 7000, 7002 and 7007?
Check fuses.Check filter caps for shorts. - Check also the small cap on the processor board.
