How do I know how much charge is left in the case ? The led indicator only show the level when it is plugged.
Welcome to BeoWorld! If you take the E8s out of the charging case and put them back in, the LEDs on the back will light up (the same as when you plug the charging case in to charge it up) and you'll be able to see how much is left.
Thx for the reply. I never noticed that it turn on when I put the earbuds back in the case. You need to be fast, it doesn't show very long.
Zordrack:Thx for the reply. I never noticed that it turn on when I put the earbuds back in the case. You need to be fast, it doesn't show very long.
Fansastic:Small question: do you encounter drop out problems as discussed elsewhere on the forum? Or does your E8 work properly? The E8 really looks great but reading all negative experience I’m hesitating.
I did the firmware update right out of the box and only experienced minor connection issue once.
I think the connection problem you heard about was before the update. It has been solved now.
When it come to wireless earbuds E8 is the best. Audio quality is fantastic and they don't have the audio lag/delay when watching videos on Netflix or YouTube like other brands.
Double post sorry
