Replacement front grilles for a pair of S 80 speakers
cwelch
Posts 1
cwelch Posted: Mon, Jun 22 2015 12:00 PM
the plastic lugs which attach the front grilles to my pair of speakers have broken such that the grilles won't stay in place. Currently use sticky tape but doesn't look very professional. Recently restored my whole system which I bought in 1980 and this is the final piece in the puzzle. Any help much appreciated. Chris
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jun 22 2015 12:08 PM
Welcome to Beoworld !
If you cannot find good panels, you could try to repair your own instead;
Grind down the remains of the old pins, glue on suitable pieces of wooden dowel pegs and paint black.
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jun 22 2015 12:47 PM
As Martin says, repair is possible. If you search the forum, you'll find threads on repairs for speaker grills/pegs. Wood dowels and rawlplugs have been used, epoxied in place, or even machined plastic/acrylic. Maybe another option is 3D printed parts. Best of luck, Dave.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jun 22 2015 6:16 PM
I used Rawlplugs for broken ones on mine - worked a treat and looked very similar to the originals
Peter
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw replied on Fri, Jun 26 2015 8:14 AM
Hi Peter
What sort of adhesive did you use? Your old MS150s need some TLC!
Cheers
Nigel
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Jun 26 2015 8:50 AM
a two-part epoxy such as Araldite will work well.  If you want a dark finish - try 'Liquid Metal'.  It sets as hard as steel and sticks to anything and is almost black once set.
Dave.
Hugo
Posts 33
Hugo replied on Mon, Apr 15 2019 1:08 AM
Oi
O meu nome é Beovox S120 eu use este automóvel Pegs, e apenas colei-o. Fácil e eficiente.
Saudações.
https://www.norauto.pt/produto/5-rebites-de-plastico-tipo-opel-chevrolet-volkswagen-audi-7-9-a-8-7mm-restagraf_215807.html?CatalogID=&CatalogCategoryName=#
Page 1 of 1 (7 items) | RSS
