i have a beo centre 4000 and the illumination under the radio display has failed. Does anyone know
How to replace or repair?
thanks
brian
I have the same problem with mine, if you look at images of the 4000 on the Internet you will see most of them look the same, I use a small torch when needed
If that's the twin-deck Beocenter 4000, I can supply correct lamps.Not too difficult to replace - but they are soldered in.
