I need to connect some audio equipment using RCA connectors to my Bevision 11. Can I use the 9-pin AV input for that? Preferrably using a short adapter like the one pictured below. (Tried that one, but it seems to be wired incorrectly.)
Any ideas?
Or if anyone knows the wiring schematics I could just solder one up myself.
Thanks kallasr,
Yes, this cable works for Beovision 11, V1, Avant (1st gen), Beosystem 4 and Beovision 12 (NG). The wiring of this AV socket is unique to B&O. This is the only way to get analogue stereo audio into one of these TVs without using converters. I can provide this cable with a Powerlink plug if required (ie. to play a Beosound into the TV speakers without needing an NL/ML Converter).
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Bought this and just got it. Works great! I'm also happy to report that the latency of the BV 11 is very minimal. Great results. Thanks!
Superb!
Thanks lundmark!
