Beoplay E8 transparency weak on right bud
This post has 7 Replies | 0 Followers
madlan
Posts 4
madlan Posted: Thu, Jan 18 2018 8:23 PM
Hi all,
Does anyone else find the left side has a much louder pass through of audio when using transparency or is it balanced? I keep looking over the wrong shoulder when disturbed at work as the balance is quite far to the left.
Thanks.
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Thu, Jan 18 2018 11:09 PM
Yeah it’s a known problem I think - both pairs I’ve had have had the problem. It is easily fixed though, all you need to do is perform a factory reset (touch the touch panel on both earbuds at the same time until the light on the right earphone goes red, and then put them back in the charging case and leave them for a few second. Then re-pair them with your phone).
Given that a factory reset of the software fixes it, hopefully they’ll work out what the problem is a patch it in a future software update.
Jon
Posts 241
Jon replied on Thu, Jan 18 2018 11:10 PM
Oh I should have said, i had issues with volume in general being quiet on the right earphone (which included transparency mode) so a factory reset /might/ not work (hopefully it will though!)
madlan
Posts 4
madlan replied on Thu, Jan 18 2018 11:53 PM
Hi Jon,
Just tried that process - it completed ok (had to pair again) but still minimal transparency on the right bud. I didn't think it would bother me but quite disorientating when moving about!
Jon
Posts 241
Jon replied on Fri, Jan 19 2018 10:26 AM
madlan:
Hi Jon,
oh no :( yeah it's quite disconcerting! If I were you I'd either take them back to the shop you bought them from for a replacement or send them off to B&O under warranty
madlan
Posts 4
madlan replied on Wed, Jan 24 2018 12:09 PM
Well this is interesting - returned them to John Lewis and ordered direct, same issue!
Is it just me being fussy? When you have transparency on - do you get much sound from the right side bud\mic? These are 1711 batch running 5.4.0 firmware.
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jan 24 2018 2:05 PM
madlan:
Uh? I don’t see how that’s interesting. They are all from the same factory, sealed and delivered. How are you expecting the hardware to differ from John Lewis?
madlan
Posts 4
madlan replied on Wed, Jan 24 2018 5:58 PM
Because B&O support stated it appears to be a hardware defect and to either return them for repair, or (as they were a few days old) return them to John Lewis for replacement\refund (who were out of stock).
Page 1 of 1 (8 items) | RSS
