Sound Center Eclipse compatible with std LG C7 tv?
This post has 2 Replies | 2 Followers
BeoMedia
Posts 100
BeoMedia Posted: Sat, Jan 27 2018 4:57 PM
Hello,
From superficial reading it looks like the monitor from LG (series C7) is identical with the unit delivered from B&O.
Would it work to buy the Sound Center from B&O and a LG C7 series tv separately? The price suggest a massive saving.
How difficult are these to combine and any limitations? Knowledge on this topic is interesting.
Regards
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 27 2018 5:36 PM
It might techically work, it might not. Eitherway the dimensions of lg’s c7 are different to the b&o version. So in that sense they would most likely not physically fit together. Iam not even sure b&o would sell it to you without the tv bit, i would guess not.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Millemissen
Flensborg, Denmark
Posts 14,680
They are listed as two different parts for the dealers.
However, I think it is more a problem of software - the displays/tvs are a slightly modified version
for use with the Beoremote and the cooperation with the SoundCenter (menus etc).
They even have a ‘BO’ behind the typenumber.
Still waiting for someone to do the test....in order to check it ——— to probably disappoint some users ;-)
Page 1 of 1 (3 items) | RSS
