Hello everyone. I am happy to have found this site. I have been receiving conflicting information on this topic:
I have a pair of MKII Pentas connected to a BeoSystem 7000 and a BL11 sub connected to my Avant. I would like to bridge the TV and the audio system.
My B&O center has a fading memory of these products sadly. They suggested a "box" (I assume 1611?) but that the 7000 must be connected by the AUX port, which is in use by my computer (DAC).
Would I have to then connect the computer to an empty port on the Avant? The description from the store seemed hopelessly complicated. Any suggestions?
Thank you!
This is how I connected my Beovision 7 40 and beosystem 7000, hope it helps
https://archivedarchivedforum2.beoworld.org/forums/p/7839/58885.aspx#58885
Paul
Thank you patcherley. I will give this a try. The graphic makes it much clearer than what the B&O rep was explaining. He made it sound as if the Avant tube would power on every time I wanted to listen to audio from the BM7000.
Now off to eBay! I will report back when everything arrives. Thank you again.
