The owner wasn't sure about model name/specs but maybe someone here is able to shed some light on this set.
I was after a CRT and picking this one up for free tomorrow, so not much of a "chance" to take, but any info about model and spec/quality would be appreciated.
thnx
May I ask, for what you are going to use this heavy-weight CTR.
By the way - here you go:
https://www.beoworld.org/prod_details.asp?pid=865
Mostly it's gonna be used for classic gaming, had to make a quick call on it as it was on it's way to the skip tomorrow.....(so it was free anyway).....:)
Once there you (probably) need two people to move it around.
If it is ok, it should be good for that purpose.
Others pick the MX series - easier to handle
Note!
You can take it apart?
At the backside there are two ‘handles’ for removing the screen part....makes it easier.
yea, we will be 2 persons handling it - any idea about the weight on these or ?
Does it compare ok to the mx series in picture quality ?
See it states roughly 50 kg on the page you linked so guess it's thereabout :)
