Hi, I have a Beolab 7.1 from US and its 110v, could it be convert to 230v for using in EU?
It is driven by ICEpower amplifier, so I guess it might have jumper to switch between different voltages?
I’m currently adapting a transformer for it , when I’m connected the powerlink to 3.5mm cable to it, the indicator turn from red to green while usb trigger on, but no sound comes out whatever source I plug with the 3.5mm. Is that cause by the voltage transformer or the problem of soundbar itself ?
Thanks a lot.
YYou only need to move the jumper. You need to dismantle it to do so. Get a repair manual It shows where it is.
That’s great. I’ll follow the service manual. Thanks.
And if the led indicator shows green , it means no problem with the speaker , right?
