I recently upgraded from a BeoSystem 3 to a BeoSystem 4. When turning on the BeoSound 5 for just music only, the BeoVision 12 comes on also and defaults to a blank screen which appears "backlit." When I am just sitting in that room listening to just music, I really don't care to see a backlit TV screen. It is very annoying to me. Is this a problem with the BeoSystem 4 too? Had the same problem with the BeoSystem 3 but thought it would have been fixed with the BeoSystem 4. Does anyone know if there is a fix for this problem? In a dark room it is really noticeable.
Hello,
the behaviour is configurable. If I remember it right, there are three options:
1. Display source (e.g. N.MUSIC)
2. Automatic / Timer (turn off screen via timer after X seconds)
3. Do not turn on TV (the TV starts up, but turns off again within a very short time)
Best regards
Doc Leisure
