BeoSound 3000 - Resetting volume control options?
DavidF
Posts 3
DavidF Posted: Mon, Mar 12 2018 1:28 PM
I have recently moved house and am trying to connect up my various B&O equipment. I have a BeoSound 3000 which was previously connected via a MasterLink system to my Beovision 6 TV and a DVD player. The two B&O speakers were connected via the TV control panel.
The BeoSound and speakers are now is a separate room without any MasterLink. When I try to turn the volume up or down, nothing happens. The sound button shows a "Use TV" message. How do I change this to allow me to operate my BeoSound as a separate entity?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Mar 12 2018 1:34 PM
DavidF:
Put the BS3000 in Option 1.
Beolink 1000: Sound-1-Store
Beo4 is a bit more tricky, so download the manual from BangOlufsen.com and see how it is done.
/Jacob
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Mar 12 2018 1:35 PM
DavidF:
The BS3000 need to be in std.by to change the Option value.
/Jacob
DavidF
Posts 3
DavidF replied on Mon, Mar 12 2018 1:42 PM
Thanks, Jacob for your speedy reply.
I am not sure how to put my BeoSound into "stand" mode or how to find Option 1. Can you help?
I am not using the BEO4 control as this operates the TV in a separate building.
DavidF
Posts 3
DavidF replied on Mon, Mar 12 2018 2:53 PM
Jacob,
Thanks; I have followed your instructions having checked the reference manual it, so all working now.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Mar 12 2018 9:00 PM
DavidF:
Jacob,
Great :)
Page 1 of 1 (6 items) | RSS
