Hi all,
I've recently bought a MMC4 cartridge online, which was supposed to be in good condition. But once I plugged it into my Beocenter 7007 the sound is very distorted. The seller says it's because of the needle pressure, but I've put that on 1.5 as stated in the specs, but the sound is still distorted.
Picture below with a close up. He told me the cartridge is in good condition, but looking at it up close I don't get the feeling it's in good condition. What do you guys think?
I agree. It could be dirt, but the cantilever looks a bit offset to the side.To judge the stylus, a close-up of the stylus from the side would've been better.
the plastic cover looks not straight - I guess this in not as advertised - if cheap, re-tip it. If expensive, return.
Peter
Thanks to all for the answers. Below is a side view, hopefully that's detailed enough?
Thanks,
Boj
Think a better closeup is needed, but form this picture the needle look a bit "rough". Dirt?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I agree, the tip looks very dirty.
Thanks both. Any tips on how to clean the tip?
As peter said if expensive just return it lots of eBay sellers sell junk,
Take a look over here for all the options offered by audio origin for repair
http://www.audio-origin.co.uk/retipping-stylus.html
or here to go through eBay
https://www.ebay.co.uk/usr/audio-origin?_trksid=p2047675.l2559
You can send it to me to get repaired, happy to clean it and check it on the microscope but it will most likely need to be repaired the angel of the cantilever does not look correct in that image, if it just needs cleaning I can return it for the postage cost.
audio.origin.uk@gmail.com
Alistair
AudioOrigin: the angel of the cantilever does not look correct in that image
on your first picture the needle seems not in the center position of the Cartridge, needs repair!
On the second Picture (look from the side) the diamond looks very bad, dirty or broken?
wilfried
